Was du brauchst
Place an opening pick between the volume button and the back cover.
Carefully remove the back cover using the metal spudger.
Use the spudger to remove the tape.
Remove the 2 J000 4 mm screws using a J000 screwdriver.
Carefully disconnect the connector port.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
