Einleitung
If your battery is not lasting as long as it used to, or not charging, this guide will show you how to replace the battery to increase the longevity of your Polaroid S7.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Insert the flat end of a soft plastic opening tool between the screen and the back cover.
Pry the two pieces apart.
Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
Pry the battery up from the right side.
