Einleitung
If your screen is cracked or it is not responding to touch, follow this guide to replace the screen.
Was du brauchst
Insert the flat end of one of the plastic opening tools between the screen and the colored back cover. Gently pry apart the pieces.
Carefully separate the screen from the back, taking care not to rip the ribbons connecting them.
After you remove the digitizer, open the latch and remove the screen.
To install the new screen, insert the digitizer into the new screen and latch them back in.
