Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
When replacing the battery, realize that there is an adhesive which binds the battery to the camera. Given the adhesive, force might be required to remove the battery. However, you should be able to remove it with your hands.
  1. Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera.  It should slide forward and unlock the clips holding it in place. Then it should be easy to simply lift the rear face plate up and remove it.
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove. Screw head: Philips, Screw length: 5mm
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Once the screws are removed, flip the camera over Use a plastic opening tool to disengage the six clips  until the front face plate can be removed safely Use a plastic opening tool to disengage the six clips  until the front face plate can be removed safely
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. The cameras innards should now be accessible to you
    • The cameras innards should now be accessible to you
  6. Two foam strips and adhesive glue binds the battery to the camera.
    • Two foam strips and adhesive glue binds the battery to the camera.
  7. Remove the battery by lifting up the battery from the left corner. If you can not remove the battery with your hands, consider using a Plastic Opening Tool
    • Remove the battery by lifting up the battery from the left corner. If you can not remove the battery with your hands, consider using a Plastic Opening Tool
  8. Using your fingers, remove the five pin connector from the device. Using your fingers, remove the five pin connector from the device.
    • Using your fingers, remove the five pin connector from the device.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Ian Colantuoni
451 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 7-3, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Mitglieder
12 Anleitungen geschrieben
Thank you so much for showing me how to do this. FYI: For the digital LCD screen version of this camera, there is only one screw to take out on that first step.
Can you tell me where I can buy the replacement battery for this camera? Thanks.
Tommy Li - Antwort
I would like to know where to buy it too.
Giorgina Nardi - Antwort
Same question need to know where to purchase a new battery and is this a common issue for the snap touch
Anita Guzman - Antwort
I also need a battery and it seems almost impossible to find one to buy. Please let me know if anybody has found a replacement battery that fits.
Jaco Botha - Antwort
Has anyone managed to find where to buy a replacement battery?
ajm.smith - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 18
Letzten 7 Tage: 133
Letzten 30 Tage: 837
Insgesamt: 27,465
