Zum Hauptinhalt wechseln
Polaroid SNAP Front and Back Face Plate Removal
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Polaroid SNAP Front and Back Face Plate Removal, Polaroid SNAP Front and Back Face Plate Removal: Schritt 1, Bild 1 von 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Front and Back Face Plate Removal: Schritt 2, Bild 1 von 2 Polaroid SNAP Front and Back Face Plate Removal: Schritt 2, Bild 2 von 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Polaroid SNAP Front and Back Face Plate Removal: Schritt 3, Bild 1 von 2 Polaroid SNAP Front and Back Face Plate Removal: Schritt 3, Bild 2 von 2
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Polaroid SNAP Front and Back Face Plate Removal: Schritt 4, Bild 1 von 3 Polaroid SNAP Front and Back Face Plate Removal: Schritt 4, Bild 2 von 3 Polaroid SNAP Front and Back Face Plate Removal: Schritt 4, Bild 3 von 3
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. Polaroid SNAP Front and Back Face Plate Removal: Schritt 5, Bild 1 von 1
    • The cameras innards should now be accessible to you
Abschluss
Aaron Hall
500 Reputation
1 Anleitung geschrieben
USF Tampa, Team 7-3, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 76
