Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show users how to remove the front and back face plates of the Polaroid SNAP.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera.  It should slide forward and unlock the clips holding it in place. Then it should be easy to simply lift the rear face plate up and remove it.
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
    • Then it should be easy to simply lift the rear face plate up and remove it.
  3. Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove. Screw head: Philips, Screw length: 5mm
    • Locate and remove the four screws on the corners of the camera, they're quite small and may be difficult to remove.
    • Screw head: Philips, Screw length: 5mm
  4. Once the screws are removed, flip the camera over Use a plastic opening tool to disengage the six clips  until the front face plate can be removed safely Use a plastic opening tool to disengage the six clips  until the front face plate can be removed safely
    • Once the screws are removed, flip the camera over
    • Use a plastic opening tool to disengage the six clips until the front face plate can be removed safely
  5. The cameras innards should now be accessible to you
    • The cameras innards should now be accessible to you
Abschluss
Aaron Hall
455 Reputation
1 Anleitung geschrieben
USF Tampa, Team 7-3, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 44
