Zum Hauptinhalt wechseln
Polaroid Z2300 Battery Replacement
  1. Polaroid Z2300 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Polaroid Z2300 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the camera upside down and gently use your thumb to pull the hatch forward and then upwards.
    • Once you lift the hatch up you will see the battery.
  2. Polaroid Z2300 Battery Replacement: Schritt 2, Bild 1 von 2 Polaroid Z2300 Battery Replacement: Schritt 2, Bild 2 von 2
    • Once you see the battery, you will see a tab saying 'pull' attached to the battery. gently pull on it until the battery is removed from the camera.
    • You can pull the battery easily afterwards.
  3. Polaroid Z2300 Battery Replacement: Schritt 3, Bild 1 von 1
    • Afterwards, you can easily reattach the battery back.
Abschluss
Jasem Almeeli
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team S13-G1, Cagle Spring 2017 Mitglied von USF Tampa, Team S13-G1, Cagle Spring 2017
USFT-CAGLE-S17S13G1
4 Mitglieder
2 Anleitungen geschrieben
2 Kommentare zur Anleitung
Do you know where to find a replacement battery? I’ve looked all over the internet.
Wendy Ralph - Antwort
I don’t have a “pull” tab, how can I get the battery out?
Sarah K - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 17
Letzte 30 Tage: 48
Insgesamt: 4,277
