Einleitung
Removing the casing is necessary to replace the LCD screen or the buttons.
Was du brauchst
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
Fast fertig!
Abschluss
