Zum Hauptinhalt wechseln
Polk MagniFi Soundbar Motherboard Replacement
Was du brauchst
  1. Polk MagniFi Soundbar Motherboard Replacement, The Motherboard: Schritt 1, Bild 1 von 1
    • To begin, remove the 8 screws locating on the back of the soundbar. These can be removed with the ifixit screwdriver equipped with a Phillips'head in size J1.
    • The cover will lift up, but there will be wires underneath connected to the cover that need to be unscrewed.
    • The 8 screws on the back cover, as well as the screws removed in the following steps, are all the exact same length (approx. 1 centimeter). Keep track of all screws but do not worry if they become mixed up.
  2. Polk MagniFi Soundbar Motherboard Replacement: Schritt 2, Bild 1 von 2 Polk MagniFi Soundbar Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the two screws using the Phillips #1 screwdriver. Once they are unscrewed, the panels will hang loose allowing unobstructed access to the motherboard.
  3. Polk MagniFi Soundbar Motherboard Replacement: Schritt 3, Bild 1 von 3 Polk MagniFi Soundbar Motherboard Replacement: Schritt 3, Bild 2 von 3 Polk MagniFi Soundbar Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Remove the three sets of wires plugged into the motherboard (image 1). These are removed by gripping the base of the wire firmly and pulling straight up.
    • Unscrew and remove the four screws (two on either side) to release the motherboard from the rest of the soundbar (Images 2 & 3).
  4. Polk MagniFi Soundbar Motherboard Replacement: Schritt 4, Bild 1 von 2 Polk MagniFi Soundbar Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Now that the soundbar is unscrewed, carefully lift the motherboard up and remove the wire attached to the underside of it. To do this firmly grasp the wires at the base (image 1) and pull them straight up.
    • The motherboard is now completely detached.
    • This component is fragile, and this step needs to be done carefully.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
[deleted]
671 Reputation
4 Anleitungen geschrieben
11 Kommentare
Where do you buy the motherboard?
luism60613 - Antwort
Where do you buy the mother board?
klwalker1965 - Antwort
Where do you buy a replacement motherboard? ???
Todd Guenther - Antwort
Same question- where do you buy the replacement motherboard?
LL Poffo - Antwort
I need a motherboard - where do I purchase it?
Tim - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 77
Insgesamt: 7,473
