Einleitung
The front three buttons on the Polk Omni S2 control the speaker's volume and are used to connect to the speaker. If any of the plastic pieces are physically damaged, follow this guide to individually replace them. Or, if the buttons aren't functioning, this guide can be used to replace the entire set.
Was du brauchst
Remove the eight 12 mm screws securing the front cover using a Phillips #1 screwdriver.
Like the grille, pull from the top middle of the gray cover and slowly remove it from the speaker, like separating a sub roll.
Remove the two square cotton pieces.
Unplug these three wires plugged into the motherboard by gently pulling and wiggling the wires until they're unplugged. Grip the wires close to the end to avoid damaging them.
Remove the four 9.5 mm screws securing the button daughterboard to the front cover using a Phillips #1 screwdriver.
Grab the gray ribbon cable as close to the connector as possible and gently wiggle and pull until it's unplugged from the button daughterboard.
Remove the rubber cover.
The plastic pieces can be removed as needed by pushing them out from the front.
