Einleitung
This guide will require you to first follow the steps to disassemble the sander pad as well as the dust seal/ brake. You will then have to disassemble the outer guard to access the fan in order for it to be replaced.
Was du brauchst
When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
Once the sander is upside down begin by removing your old sandpaper.
Once the sandpaper is removed locate the three screws on your sander pad.
Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Once the sander pad is removed and the sander is exposed locate the white plastic like circular piece surrounding the outside of the sander.
Once you have located the plastic white ring pull up its outer edge as shown. The lip on the inside will bend and be freed from its secured placement.
Once the dust brake/ seal is removed locate the screw in the center of the device holding down the bearing and fan assembly.
unscrew this bolt using a T20 star bit and carefully remove the washer and bearing as shown.
Next locate the bolts holding down the guard assembly as shown. There will be one bolt on each side, two in total.
Using a T15 star bit unscrew these bolts and make sure you keep them in a safe place.
Once the two screws are removed locate the o-ring that seals the dust collector to its opening.
Very delicately pry the o-ring out of its slot using a nylon spudger or plastic opening tool. Then roll it off of the opening as shown.
The fan can then simply be pulled from its axle and be replaced with the fan blades facing up.
Eine weitere Person hat diese Anleitung absolviert.
