Zum Hauptinhalt wechseln
Porter-Cable 382 On/ Off Switch Replacement
Was du brauchst
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: Schritt 1, Bild 1 von 2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: Schritt 1, Bild 2 von 2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: Schritt 2, Bild 1 von 2 Porter-Cable 382 On/ Off Switch Replacement: Schritt 2, Bild 2 von 2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: Schritt 3, Bild 1 von 1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Abschluss
Nick O'Sadcia
421 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 233
