Zum Hauptinhalt wechseln
Porter-Cable 382 Sander Pad Replacement
Was du brauchst
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: Schritt 1, Bild 1 von 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: Schritt 2, Bild 1 von 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Nick O'Sadcia
421 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Mitglied von UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 1,785
