Zum Hauptinhalt wechseln
Porter-Cable PC60TAG Motor Brush Replacement
Was du brauchst
  1. Porter-Cable PC60TAG Motor Brush Replacement, Motor Brush: Schritt 1, Bild 1 von 1
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Motor Brush Replacement: Schritt 2, Bild 1 von 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Brush Replacement: Schritt 3, Bild 1 von 1
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
  4. Porter-Cable PC60TAG Motor Brush Replacement: Schritt 4, Bild 1 von 1
    • Carefully pull the motor brush arm away from the other device.
  5. Porter-Cable PC60TAG Motor Brush Replacement: Schritt 5, Bild 1 von 1
    • Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
    • Be careful not to over bend the spring, as this could damage the spring and require replacement.
  6. Porter-Cable PC60TAG Motor Brush Replacement: Schritt 6, Bild 1 von 2 Porter-Cable PC60TAG Motor Brush Replacement: Schritt 6, Bild 2 von 2
    • Using the spudger, gently push the motor brush out of the arm.
  7. Porter-Cable PC60TAG Motor Brush Replacement: Schritt 7, Bild 1 von 1
    • Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
    • Repeat steps 3-7 on the other side of the device.
Abschluss
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 Mitglied von UMass Dartmouth, Team 2-2, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 820
