Was du brauchst
Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm. Repeat on the other side.
Carefully pull the motor brush arm away from the other device, you can leave the wire connected to device. Repeat on the other side.
Using the Phillips #2 screwdriver, remove the four, 1/2" Phillips screws around the head gear.
Using the Phillips #2 screwdriver, remove the two 1/2" Phillips screws holding the head to the body on the bottom side of the grinder.
Using the Phillips #2 screwdriver, remove the other two 1/2" Phillips screws holding the head to the body on the top side of the grinder.
Holding the head of the device, carefully pull the motor assembly out of the body of the device.
Using a 9/16" wrench, loosen the spindle nut inside the head, from the motor assembly.
