Einleitung
Often times power cords can get damaged through long-term use, or mishandling of the device. Whatever the case, the power cord of the Porter-Cable PC60TAG can be replaced in a few easy steps.
Was du brauchst
Using the Phillips #2 screwdriver, remove the 3/4" Phillips head screw on the back cover.
Using the Phillips #2 screwdriver, remove the two 1/2" Phillips head screws securing the cord grip.
Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
