Einleitung
Often times, a grinder that won't power on is due to a faulty power switch. This mechanical part may fail over time, resulting in the need to replace it. Use this guide to replace the power switch in your Porter-Cable PC60TAG.
Was du brauchst
Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
From the other side of the device, use the spudger to carefully pry out power switch away from the device.
Using your fingers, carefully remove each of the gold terminals from the power switch. You may need to gently wiggle the terminal back and forth in order to remove it.
