Einleitung
If you need to replace the anvil of your Porter-Cable PCE211 drill, follow this guide.
Be sure to turn the drill off and unplug it from the power source prior to beginning the repair.
Was du brauchst
Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
Abschluss
