Zum Hauptinhalt wechseln
Porter-Cable PCE211 Fan Replacement
Was du brauchst
    1. Porter-Cable PCE211 Fan Replacement, Gearcase: Schritt 1, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Gearcase: Schritt 1, Bild 2 von 2
      • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
      Frag FixBot
      Kommentar hinzufügen
    2. Porter-Cable PCE211 Fan Replacement: Schritt 2, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 2, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 2, Bild 3 von 3
      • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
      • Be careful about any loose parts when removing the head.
      Frag FixBot
    1. Porter-Cable PCE211 Fan Replacement, Anvil: Schritt 3, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement, Anvil: Schritt 3, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement, Anvil: Schritt 3, Bild 3 von 3
      • Firmly pull the to remove drill bit holder also known as the anvil.
      • Before replacing the anvil, lubricate the base for the best performance.
      Frag FixBot
    1. Porter-Cable PCE211 Fan Replacement, Motor: Schritt 4, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement, Motor: Schritt 4, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement, Motor: Schritt 4, Bild 3 von 3
      • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
      • Pull the motor out with your hands.
      Frag FixBot
    2. Porter-Cable PCE211 Fan Replacement: Schritt 5, Bild 1 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 5, Bild 2 von 3 Porter-Cable PCE211 Fan Replacement: Schritt 5, Bild 3 von 3
      • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
      Frag FixBot
    1. Porter-Cable PCE211 Fan Replacement, Rear Housing: Schritt 6, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Rear Housing: Schritt 6, Bild 2 von 2
      • Remove the four 6 mm screws using a Phillips #2 screwdriver.
      • The screws are tight so you will need to use a bit of arm strength.
      Frag FixBot
    2. Porter-Cable PCE211 Fan Replacement: Schritt 7, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement: Schritt 7, Bild 2 von 2
      • Pull the rear housing off the back of the impact wrench.
      • Be careful when removing the rear case that loose parts don't get damaged.
      Frag FixBot
    1. Porter-Cable PCE211 Fan Replacement, Grip: Schritt 8, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Grip: Schritt 8, Bild 2 von 2
      • Using the Phillips #2 screwdriver, remove the three 8 mm screws from the grip of the impact wrench.
      Frag FixBot
    2. Porter-Cable PCE211 Fan Replacement: Schritt 9, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement: Schritt 9, Bild 2 von 2
      • Pull the grip from the body of the impact wrench.
      Frag FixBot
    1. Porter-Cable PCE211 Fan Replacement, Fan: Schritt 10, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement, Fan: Schritt 10, Bild 2 von 2
      • Lift the hammer block (which is attached to the fan) out of the case.
      • It is a little heavy so be careful when lifting it out.
      Frag FixBot
    2. Porter-Cable PCE211 Fan Replacement: Schritt 11, Bild 1 von 2 Porter-Cable PCE211 Fan Replacement: Schritt 11, Bild 2 von 2
      • If you're doing maintenance and the fan isn't damage, use a microfiber cloth to clean the fan.
      • Wipe well until there's no residue or oil lubricant.
      Frag FixBot
Abschluss
Austin Community College, Team 13-1, Watkins Fall 2022 Mitglied von Austin Community College, Team 13-1, Watkins Fall 2022
AUSTINCC-WATKINS-F22S13G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 430
