Zum Hauptinhalt wechseln
Porter-Cable PCE211 Motor Replacement
Was du brauchst
    1. Porter-Cable PCE211 Motor Replacement, Gearcase: Schritt 1, Bild 1 von 2 Porter-Cable PCE211 Motor Replacement, Gearcase: Schritt 1, Bild 2 von 2
      • Using the Hex Security SAE 7/32", remove the four 10 mm socket screws at the base of the gearcase.
      Frag FixBot
      Kommentar hinzufügen
    2. Porter-Cable PCE211 Motor Replacement: Schritt 2, Bild 1 von 3 Porter-Cable PCE211 Motor Replacement: Schritt 2, Bild 2 von 3 Porter-Cable PCE211 Motor Replacement: Schritt 2, Bild 3 von 3
      • Grip the body of the impact wrench with one hand and the gearcase in the other and firmly pull to remove it.
      • Be careful about any loose parts when removing the head.
      Frag FixBot
    1. Porter-Cable PCE211 Motor Replacement, Anvil: Schritt 3, Bild 1 von 3 Porter-Cable PCE211 Motor Replacement, Anvil: Schritt 3, Bild 2 von 3 Porter-Cable PCE211 Motor Replacement, Anvil: Schritt 3, Bild 3 von 3
      • Firmly pull the to remove drill bit holder also known as the anvil.
      • Before replacing the anvil, lubricate the base for the best performance.
      Frag FixBot
    1. Porter-Cable PCE211 Motor Replacement, Motor: Schritt 4, Bild 1 von 3 Porter-Cable PCE211 Motor Replacement, Motor: Schritt 4, Bild 2 von 3 Porter-Cable PCE211 Motor Replacement, Motor: Schritt 4, Bild 3 von 3
      • This section tends to get messy so it would be best to have a paper towel or microfiber towel handy.
      • Pull the motor out with your hands.
      Frag FixBot
    2. Porter-Cable PCE211 Motor Replacement: Schritt 5, Bild 1 von 3 Porter-Cable PCE211 Motor Replacement: Schritt 5, Bild 2 von 3 Porter-Cable PCE211 Motor Replacement: Schritt 5, Bild 3 von 3
      • Wipe out the old grease with a towel. Use the appropriate motor grease for electric tools to lubricate the top area, base of the motor, and the space the motor sits.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Austin Community College, Team 13-1, Watkins Fall 2022 Mitglied von Austin Community College, Team 13-1, Watkins Fall 2022
AUSTINCC-WATKINS-F22S13G1
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 469
