Einleitung
Installing the video card involves removing the outer case before actual installation.
Was du brauchst
Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
Push back the handle after you have taken the core out of the case.
Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
Remove the power cord.
Remove the connector.
Remove the video card from the logic board.
9 weitere Nutzer:innen haben diese Anleitung absolviert.
