Zum Hauptinhalt wechseln
Power Mac G4 M5183 Processor Replacement
Was du brauchst
  1. Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: Schritt 1, Bild 1 von 2 Power Mac G4 M5183 Processor Replacement, Opening PowerMac G4 M5183 Case: Schritt 1, Bild 2 von 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
    Frag FixBot
    Kommentar hinzufügen
  2. Power Mac G4 M5183 Processor Replacement, Heat Sink: Schritt 2, Bild 1 von 2 Power Mac G4 M5183 Processor Replacement, Heat Sink: Schritt 2, Bild 2 von 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
    Frag FixBot
  3. Power Mac G4 M5183 Processor Replacement: Schritt 3, Bild 1 von 1
    • Remove the heat sink by pulling upwards, off of the logic board.
    Frag FixBot
  4. Power Mac G4 M5183 Processor Replacement, Processor: Schritt 4, Bild 1 von 2 Power Mac G4 M5183 Processor Replacement, Processor: Schritt 4, Bild 2 von 2
    • Remove the 3 screws attaching the processor to the logic board using the Phillips #2 screwdriver.
    • Remove processor by pulling vertically upwards.
    Frag FixBot
Ziellinie
14 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 13-24, Maness Winter 2010 Mitglied von Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 Mitglieder
37 Anleitungen geschrieben
2 Kommentare zur Anleitung
anyone still sell the replacement processor?
Joseph Cole - Antwort Teilen
Anyone who has upgraded their CPU’s manage to flash from MacPro1,1 to MacPro2,1? And If so How?
Michael Inman - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 68
Insgesamt: 12,916
