Zum Hauptinhalt wechseln
Einleitung
This is meant to be a private prereq guide.
Ersatzteile
Keine Ersatzteile angegeben.
  1. The hard drive is located in the back right corner of the case.
    • The hard drive is located in the back right corner of the case.
  2. Remove the flat ribbon cable by pulling with substantial force.
    • Remove the flat ribbon cable by pulling with substantial force.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Remove the screw holding the hard drive to the computer.
    • Remove the screw holding the hard drive to the computer.
  5. Pull the drive up and out of the computer.
    • Pull the drive up and out of the computer.
  6. Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
    • Remove the multicolored cable by grasping the plastic connector on either side and pulling with substantial force.
Abschluss
10 weitere Nutzer haben diese Anleitung absolviert.
Ryan Bylard
1.275 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 14-41, Regan Winter 2010 Mitglied von Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Mitglieder
10 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 7,207
