Zum Hauptinhalt wechseln
Power Mac G4 Quicksilver Logic Board Replacement
Was du brauchst
  1. Power Mac G4 Quicksilver Logic Board Replacement, Opening the case: Schritt 1, Bild 1 von 1
    • The handle to open your computer is located on top of the right side panel.
  2. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 2, Bild 1 von 2 Power Mac G4 Quicksilver Logic Board Replacement: Schritt 2, Bild 2 von 2
    • Grab the circular handle and pull outward.
  3. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Your computer is now open and ready for repair.
  4. Power Mac G4 Quicksilver Logic Board Replacement, Video Adapter: Schritt 4, Bild 1 von 1
    • This is your Power Mac G4's video adapter.
  5. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 5, Bild 1 von 1
    • Start by removing the screw holding the card to the chassis as shown.
  6. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
  7. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 7, Bild 1 von 2 Power Mac G4 Quicksilver Logic Board Replacement: Schritt 7, Bild 2 von 2
    • With the tab and screw removed, lift the card straight out.
    • When putting the card back in, take care to apply even pressure across the top with your thumbs. This will avoid damaging the card.
  8. Power Mac G4 Quicksilver Logic Board Replacement, Logic Board: Schritt 8, Bild 1 von 1
    • Disconnect both the power cables and IDE cable from the mother board.
  9. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 9, Bild 1 von 1
    • Remove these three screws that hold the motherboard fan and modem connector to the chassis.
  10. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 10, Bild 1 von 1
    • Remove the four screws shown to free the mother board from the chassis.
  11. Power Mac G4 Quicksilver Logic Board Replacement: Schritt 11, Bild 1 von 3 Power Mac G4 Quicksilver Logic Board Replacement: Schritt 11, Bild 2 von 3 Power Mac G4 Quicksilver Logic Board Replacement: Schritt 11, Bild 3 von 3
    • Lift the fan shroud and fan straight up and out. Take care to disconnect the indicated connector
    • Remove the heatsink clamps with a flathead screwdriver and do the same for the other side.
    • Lift off the heatsink and remove the 4 screws of the CPU board.
    • There are 4 pins: remove the 3 pins near the RAM but not the pin nearest You.
    • You are now ready to slide gently (and without ANY difficult) the motherboard. Lift up and the game is done.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 14-41, Regan Winter 2010 Mitglied von Cal Poly, Team 14-41, Regan Winter 2010
CPSU-REGAN-W10S14G41
4 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 16,867
