Zum Hauptinhalt wechseln
PowerA Enhanced Wireless Controller Action Buttons Replacement
Was du brauchst
  1. PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: Schritt 1, Bild 1 von 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: Schritt 1, Bild 2 von 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
    Frag FixBot
  2. PowerA Enhanced Wireless Controller Action Buttons Replacement: Schritt 2, Bild 1 von 1
    • Remove all eight screws using the J0 screwdriver.
    Frag FixBot
  3. PowerA Enhanced Wireless Controller Action Buttons Replacement: Schritt 3, Bild 1 von 2 PowerA Enhanced Wireless Controller Action Buttons Replacement: Schritt 3, Bild 2 von 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
    Frag FixBot
  4. PowerA Enhanced Wireless Controller Action Buttons Replacement: Schritt 4, Bild 1 von 3 PowerA Enhanced Wireless Controller Action Buttons Replacement: Schritt 4, Bild 2 von 3 PowerA Enhanced Wireless Controller Action Buttons Replacement: Schritt 4, Bild 3 von 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
    Frag FixBot
  5. PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: Schritt 5, Bild 1 von 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: Schritt 5, Bild 2 von 3 PowerA Enhanced Wireless Controller Action Buttons Replacement, Action Buttons: Schritt 5, Bild 3 von 3
    • Use the iFixit opening tool to lift the action button out from its place.
    • Pull the button out with your fingers.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S1-G5, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Mitglieder
11 Anleitungen geschrieben
3 Kommentare zur Anleitung
Where do you buy the buttons ?? I haven’t been able to find them
Captain Chris Sherwood - Antwort Teilen
Where can I buy the buttons?
Justinas Maraulis - Antwort Teilen
For me, it's not the buttons, but the silicone pads for ABXY that have worn out. I've looked everywhere, but to no avail.
Radiohead - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 21
Letzte 30 Tage: 95
Insgesamt: 5,363
