Zum Hauptinhalt wechseln
PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement
Was du brauchst
  1. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: Schritt 1, Bild 1 von 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: Schritt 1, Bild 2 von 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Remove the battery cover by pressing down on the lever located on the top of the cover.
    • Apply pressure until it clicks out of place, and pull it off.
    Frag FixBot
  2. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove all eight screws using the J0 screwdriver.
    Frag FixBot
  3. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: Schritt 3, Bild 1 von 2 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: Schritt 3, Bild 2 von 2
    • Insert the iFixit opening tool into the seam and gently pry the cover plate up.
    • Remove the cover plate once it is loosened.
    Frag FixBot
  4. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: Schritt 4, Bild 1 von 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: Schritt 4, Bild 2 von 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement: Schritt 4, Bild 3 von 3
    • Remove all three screws securing the motherboard using the J00 screwdriver.
    • Remove the motherboard.
    Frag FixBot
  5. PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: Schritt 5, Bild 1 von 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: Schritt 5, Bild 2 von 3 PowerA Enhanced Wireless Controller L and R Thumbstick Cover Replacement, L and R Thumbsticks Covers: Schritt 5, Bild 3 von 3
    • Pull the L and R stick covers out of the socket.
    Frag FixBot
Abschluss
13 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S1-G5, Leahy Fall 2019 Mitglied von USF Tampa, Team S1-G5, Leahy Fall 2019
USFT-LEAHY-F19S1G5
3 Mitglieder
11 Anleitungen geschrieben
21 Kommentare zur Anleitung
My controllers are drifting, What can i do after getting the joystick of to fix that.
MilesGDC - Antwort Teilen
i dont know i cleaned using plush sticks ( that usually go to ears that one ) i used that and isopropacol alcohoc 90%
it works for 2 weeks ( on me ) and now my Right analog stick is too Loose to wiggle there
BrunoS - Antwort Teilen
Where can I get replacement thumbsticks for this controller? Are they the same as the Switch Pro Controllers?
engelgott0972 - Antwort Teilen
i need replacement joy-sticks too
I need a link for the thumbsticks too. Cant seem to find them anywhere and PowerA does no sell them nor is willing to help.
Brandon Kohl - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 127
Insgesamt: 16,931
