Einleitung
The headphone jack on the PowerA Fusion Controller For Xbox One allows you to plug headphones into the controller to listen to audio or talk with others. This repair will be needed if the headphone jack no longer plays or picks up audio. This guide will walk you through replacing the headphone jack on the controller. During the repair you will need to do some soldering.
Was du brauchst
Remove the (9) nine 9.2mm screws (circled in red) with a JIS #1 screwdriver.
Remove the two bottom plastic grip covers.
Remove the (2) two 9.2mm screws (circled in red) with a JIS #1 screwdriver.
Remove the back cover of the controller as seen in image (2) two.
Desolder the soldered joints that are connecting the headphone jack to the motherboard (Circled in red).
This guide will show you how to solder and desolder connections.
Remove the headphone jack and put it aside.
2 Kommentare zur Anleitung
Has this been proven to work? Thanks!
real help full its like having a broken down car and a video online saying “open bonnet and fix car” no mention of where you can get those parts ie the most important bit the parts ie the female jack port !!!! other than not for sale !! blinding
