Zum Hauptinhalt wechseln
PowerA Fusion Controller For Xbox One Motherboard Replacement
Was du brauchst
  1. PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: Schritt 1, Bild 1 von 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: Schritt 1, Bild 2 von 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Vibration Motors: Schritt 1, Bild 3 von 3
    • Remove the nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
    Frag FixBot
    Kommentar hinzufügen
  2. PowerA Fusion Controller For Xbox One Motherboard Replacement: Schritt 2, Bild 1 von 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
    Frag FixBot
  3. PowerA Fusion Controller For Xbox One Motherboard Replacement: Schritt 3, Bild 1 von 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Take off the glue that is on top of the soldered joints with a sprudger.
    • Desolder the soldered joints of the red and black wires that are connecting the vibration motors to the motherboard.
    • Remove the vibration motors and put them aside.
    • This guide will show how to solder and desolder connections.
    Frag FixBot
  4. PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 3 PowerA Fusion Controller For Xbox One Motherboard Replacement, Motherboard: Schritt 4, Bild 3 von 3
    • Remove the five 9.2mm screws with a JIS #1 screwdriver. Indicated by the red circles.
    • Lift the motherboard and let it hang.
    Frag FixBot
  5. PowerA Fusion Controller For Xbox One Motherboard Replacement: Schritt 5, Bild 1 von 2 PowerA Fusion Controller For Xbox One Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 9.2mm screws that are holding the D-Pad to the controller housing. Indicated by the red circles.
    • Remove the motherboard.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Andrea
668 Reputation
4 Anleitungen geschrieben
USF Tampa, Team S14-G4, Boczar Fall 2017 Mitglied von USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 Mitglieder
7 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hi I have a powera fusion controler model CPFA115315-02 and I took the controller apart to clean and I forgot how the lb rb button springs go, I look on the internet and couldn't find anything. Any help would be great
Thanks
Nhgamer - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 52
Insgesamt: 4,080
