Zum Hauptinhalt wechseln
PowerA Spectra Contoller Bumper Replacement
Was du brauchst
  1. PowerA Spectra Contoller Bumper Replacement, Rear Case: Schritt 1, Bild 1 von 1
    • Flip the controller over so the backplate is facing up.
    Frag FixBot
    Kommentar hinzufügen
  2. PowerA Spectra Contoller Bumper Replacement: Schritt 2, Bild 1 von 1
    • Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
    Frag FixBot
  3. PowerA Spectra Contoller Bumper Replacement: Schritt 3, Bild 1 von 1
    • Hold the front case in one hand and pull the rear case off.
    Frag FixBot
  4. PowerA Spectra Contoller Bumper Replacement, Bumper: Schritt 4, Bild 1 von 1
    • Remove the two 7.8 mm screws from the motherboard with a Phillips screwdriver.
    Frag FixBot
  5. PowerA Spectra Contoller Bumper Replacement: Schritt 5, Bild 1 von 1
    • Grasp the front plate and motherboard and slowly pull apart to access the bumpers.
    Frag FixBot
  6. PowerA Spectra Contoller Bumper Replacement: Schritt 6, Bild 1 von 1
    • Use angled tweezers to unclip the bumper spring from the front plate.
    Frag FixBot
  7. PowerA Spectra Contoller Bumper Replacement: Schritt 7, Bild 1 von 1
    • Lift up the bumper and slide off the bumper axis to remove.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 289
