Einleitung
This guide includes instructions on how to remove and replace the D-Pad button from the PowerA Spectra controller.
The D-Pad is a plus-symbol-shaped button that allows for four different inputs. The button can usually fail to work because of dirt buildup in the button itself.
Make sure to disconnect the controller from any electrical sources before beginning.
Was du brauchst
Use a Phillips #2 screwdriver to remove the eight 7.8 mm screws that secure the rear case.
Use a Phillips screwdriver to remove the two 7.8 mm screws securing the motherboard to the chassis.
Use Phillips screwdriver to remove the four 7.8 mm screws that secure the D-pad.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
