Einleitung
Use this guide to replace the bumpers of a Power A Spectra Infinity Enhanced Xbox controller.
The bumpers may need to be replaced if they no longer press down, get stuck, or do not provide imput to the controller when plugged in. Please ensure that the controller is not plugged in before taking it apart.
Was du brauchst
Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
Unlock the trigger locks before removing the backplate.
Use your fingers and carefully remove the backplate.
Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
Remove two 10 mm screws holding the bumper to the faceplate using a Phillips #0 screwdriver.
Remove the single 7.9 mm screw holding the bumpers to the faceplate using a Phillips #0 screwdriver.
3 weitere Personen haben diese Anleitung absolviert.
