Zum Hauptinhalt wechseln
PowerA Spectra Infinity Enhanced Joysticks Replacement
Was du brauchst
  1. PowerA Spectra Infinity Enhanced Joysticks Replacement, Motherboard: Schritt 1, Bild 1 von 2 PowerA Spectra Infinity Enhanced Joysticks Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Flip the controller so the back is facing up.
    Frag FixBot
  2. PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
    Frag FixBot
  3. PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 3, Bild 1 von 2 PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 3, Bild 2 von 2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
    Frag FixBot
  4. PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
    Frag FixBot
  5. PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 5, Bild 1 von 2 PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 5, Bild 2 von 2
    • Use your hand to separate the motherboard from the face plate.
    Frag FixBot
  6. PowerA Spectra Infinity Enhanced Joysticks Replacement, Joysticks: Schritt 6, Bild 1 von 1
    • Take the motherboard and place it with the joysticks facing upward.
    Frag FixBot
  7. PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 7, Bild 1 von 3 PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 7, Bild 2 von 3 PowerA Spectra Infinity Enhanced Joysticks Replacement: Schritt 7, Bild 3 von 3
    • Use your hand to carefully remove the joysticks from the motherboard.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 6-5, Botvin Spring 2024 Mitglied von UMass Dartmouth, Team 6-5, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 119
Insgesamt: 2,457
