Einleitung
Use this guide to replace the vibration motors of a Power A Spectra Infinity Enhanced Xbox controller.
The vibration motors may need to be replaced if they no longer vibrate when plugged in and taking part in a game that supports vibrating feedback. Please ensure that the controller is not plugged before taking it apart.
Was du brauchst
Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
Unlock the trigger locks before removing the backplate.
Use your fingers and carefully remove the backplate.
Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
Remove the four 7.9 mm screws using a Phillips #0 screwdriver.
Use tweezers to unplug the small plug connecting the motors to the motherboard.
2 weitere Personen haben diese Anleitung absolviert.
