Zum Hauptinhalt wechseln
PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement
Was du brauchst
  1. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery.: Schritt 1, Bild 1 von 1
    • The battery is located inside the right side ear piece.
  2. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Heat Right Side.: Schritt 2, Bild 1 von 1
    • Heat the right side gently at 140 F for about 3 minutes.
    • Do not over heat or it will melt the housing.
  3. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: Schritt 3, Bild 1 von 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Remove Battery Cover/Casing: Schritt 3, Bild 2 von 2
    • After heating, gently remove the cover/casing as shown in the picture.
    • Take your time and re-heat if cover/casing does not remove smoothly.
  4. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Desolder & Replace Battery: Schritt 4, Bild 1 von 1
    • Desolder battery using soldering iron and replace with replacement battery.
  5. PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: Schritt 5, Bild 1 von 2 PowerBeats2 Wireless Headphones by Dr. Dre Battery Replacement, Reattach Battery Cover/Casing: Schritt 5, Bild 2 von 2
    • After battery is replaced, apply super glue to the border of the inside of the battery cover/casing and put it back in place.
    • Use small clamps/binder clip to hold the housing in place while the super glue dries up.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Faizan Naveed
3.294 Reputation
8 Anleitungen geschrieben
Mobile Device Repair Factory Mitglied von Mobile Device Repair Factory
Business
1 Mitglied
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 15
Letzte 30 Tage: 48
Insgesamt: 26,834
