Zum Hauptinhalt wechseln
  1. Battery is located in the right side headphone housing. Battery is located in the right side headphone housing.
    • Battery is located in the right side headphone housing.
  2. Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures. After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures. After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. Use a soldering iron to desolder battery connection to remove battery and replace with new one.
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
Abschluss
12 weitere Nutzer haben diese Anleitung absolviert.
Faizan Naveed
3.168 Reputation
8 Anleitungen geschrieben
Mobile Device Repair Factory Mitglied von Mobile Device Repair Factory
Business
1 Mitglied
9 Anleitungen geschrieben
3 Kommentare
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
Joe's GE - Antwort
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - Antwort
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 16
Letzten 30 Tage: 140
Insgesamt: 24,087
