Zum Hauptinhalt wechseln
PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement
Was du brauchst
  1. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: Schritt 1, Bild 1 von 2 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Locate Battery Side: Schritt 1, Bild 2 von 2
    • Battery is located in the right side headphone housing.
  2. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Heat Battery Housing: Schritt 2, Bild 1 von 1
    • Use a heat gun with temperature set to 140 F for about 2-3 minutes and heat the casing where it attaches together as seen in the picture.
  3. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: Schritt 3, Bild 1 von 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: Schritt 3, Bild 2 von 3 PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove Housing: Schritt 3, Bild 3 von 3
    • After heating for about 2-3 minutes, separate the housing using a pry tool as seen in the pictures.
  4. PowerBeats3 Wireless Headphones by Dr. Dre Battery Replacement, Remove/Replace Battery: Schritt 4, Bild 1 von 1
    • Use a soldering iron to desolder battery connection to remove battery and replace with new one.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Faizan Naveed
3.294 Reputation
8 Anleitungen geschrieben
Mobile Device Repair Factory Mitglied von Mobile Device Repair Factory
Business
1 Mitglied
16 Anleitungen geschrieben
5 Kommentare
If you need this part you can order it here
https://www.joesge.com/products/powerbea...
JoesGE - Antwort
My battery only was connected by two wires. Is that a newer edition of the Powerbeats than this one? Has Apple changed their wiring?
Andrew Manwaring - Antwort
Where can I get the batteries? Is it available besides beats showroom?
Tara Chandrabura - Antwort
My bettry is too good work but tha wireis want to b change
Asoo Malik - Antwort
Plzz tel me how I can change tha wire of my power beats
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 116
Insgesamt: 28,874
