Zum Hauptinhalt wechseln
PowerBook 180 Ram Replacement
Was du brauchst
  1. PowerBook 180 Ram Replacement, Ram: Schritt 1, Bild 1 von 2 PowerBook 180 Ram Replacement, Ram: Schritt 1, Bild 2 von 2
    • The PowerBook 180 has a removable Ni-Cad battery on the side. Before we start this repair, we need to make sure the computer does not have any power source - so you don't get shocked and the computer doesn't die.
    • Slide the battery door to the front of the computer, as directed by the arrows.
    • Pull out the battery.
  2. PowerBook 180 Ram Replacement: Schritt 2, Bild 1 von 2 PowerBook 180 Ram Replacement: Schritt 2, Bild 2 von 2
    • There are 5 Torx T8 screws that hold the bottom of the PowerBook 180.
    • 4 are on the side, and one is above the modem port at the back of the computer.
    • Remove these screws.
  3. PowerBook 180 Ram Replacement: Schritt 3, Bild 1 von 2 PowerBook 180 Ram Replacement: Schritt 3, Bild 2 von 2
    • Remove the bottom plate by prying up with either a flathead screwdriver or plastic object, such as a credit card.
    • Keep in mind the bottom left and right corners of the PowerBook 180 is very hard to open - you may need to use some extra force to open that side.
    • Your PowerBook 180 should look like the two pictures - with separate top and bottom halves.
  4. PowerBook 180 Ram Replacement: Schritt 4, Bild 1 von 1
    • Identify the RAM in the PowerBook 180. It is marked in red in the picture.
    • For this PowerBook, there is 4mb of Kingston RAM - a lot back in those times!
  5. PowerBook 180 Ram Replacement: Schritt 5, Bild 1 von 2 PowerBook 180 Ram Replacement: Schritt 5, Bild 2 von 2
    • Remove the RAM by using a plastic object (such as a credit card) along the red marked area in the picture. The RAM is very flexible, so be very careful.
    • Now place the new RAM into the empty socket.
    • Follow these instructions in reverse order to reassemble the PowerBook 180.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jack Byrnes
1.244 Reputation
2 Anleitungen geschrieben
Master Techs Mitglied von Master Techs
Community
321 Mitglieder
1.468 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 30
Insgesamt: 3,192
