Einleitung
If your hard drive was damaged or you want to upgrade it you will need to remove the old hard drive first. However, the hard drive is one of the hardest components to reach. Make sure you are able to keep all removed parts organized to make your reassembly process easier.
Was du brauchst
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Turn the computer over and open the display. You should see that the keyboard is loose.
Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
Carefully lift the top half of the keyboard and pull it towards yourself.
Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
Gently remove the ribbons from its tabs.
To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
Once loose, pull the ribbon cable free.
Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
Push the display screen back to give yourself enough space to remove the side panels.
Remove the panels on either side by gently but firmly pulling up on them with both hands.
Use the plastic opening tool to lift up the tabs on either side of the ribbon cable port and then gently pull the ribbon cable free.
With your index finger and your thumb, squeeze the track pad panel to loosen the clamps. Then slide the panel towards yourself.
Remove the three T8 10mm long torx screws along the bottom of the casing next to the hard drive.
Rotate the hard drive towards yourself to access the ribbon cable and then gently pull up on the ribbon cable connector to remove the cable.
Place the hard drive so that the casing is facing up.
Remove the 4 T8 5mm long torx screws to remove the hard drive from the metal casing.
Remove and set aside the black protector that was under the hard drive casing.
Use a plastic opening tool to loosen the ribbon cable by running it along the connection and gently prying it free.
When you have loosened the connection, pull the tab to remove the ribbon cable.
Install the new hard drive by following these instructions in reverse order.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
