Einleitung
In order to access the display or replace any portion of the sound system you must first remove the speaker panel from the computer.
Was du brauchst
Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
Turn the computer over and open the display. You should see that the keyboard is loose.
Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
Carefully lift the top half of the keyboard and pull it towards yourself.
Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
Gently remove the ribbons from its tabs.
To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
Once loose, pull the ribbon cable free.
Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
