Zum Hauptinhalt wechseln
PowerBook 3400 M3553 Speaker Panel Replacement
Was du brauchst
  1. PowerBook 3400 M3553 Speaker Panel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Close the screen and turn the PowerBook over, orienting the computer upside down, using the label to guide you.
  2. PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 2, Bild 1 von 2 PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 2, Bild 2 von 2
    • Hold the button on the front left side and slide the battery out.
  3. PowerBook 3400 M3553 Speaker Panel Replacement, Keyboard: Schritt 3, Bild 1 von 1
    • With a Torx T8 screwdriver, remove the three Torx 24mm screws along the center of the back panel.
  4. PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 4, Bild 1 von 3 PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 4, Bild 2 von 3 PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 4, Bild 3 von 3
    • Turn the computer over and open the display. You should see that the keyboard is loose.
    • Before attempting to remove the keyboard, note that a ribbon cable connects the keyboard to the logic board. Improper removal may damage your keyboard.
    • Slightly lift the front of the keyboard up, and slide the keyboard towards yourself.
    • Carefully lift the top half of the keyboard and pull it towards yourself.
  5. PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 5, Bild 1 von 2 PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 5, Bild 2 von 2
    • Loosen the ribbon cables connecting the keyboard to the computer by using a plastic opening tool to lift the tabs on either side of the cable port.
    • Gently remove the ribbons from its tabs.
  6. PowerBook 3400 M3553 Speaker Panel Replacement, RAM: Schritt 6, Bild 1 von 2 PowerBook 3400 M3553 Speaker Panel Replacement, RAM: Schritt 6, Bild 2 von 2
    • Gently wiggle the RAM card to loosen the connection until it pulls free.
  7. PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: Schritt 7, Bild 1 von 2 PowerBook 3400 M3553 Speaker Panel Replacement, Speaker Panel: Schritt 7, Bild 2 von 2
    • Disconnect the wires from the port.
  8. PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 8, Bild 1 von 1
    • Remove the 7mm screw connecting the speaker panel to the computer.
  9. PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 9, Bild 1 von 2 PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 9, Bild 2 von 2
    • To detach the speaker panel's ribbon cable, use a plastic opening tool to lift the tabs on both sides of the cable port.
    • Once loose, pull the ribbon cable free.
  10. PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 10, Bild 1 von 2 PowerBook 3400 M3553 Speaker Panel Replacement: Schritt 10, Bild 2 von 2
    • Lift the lighting/audio panel from it's bottom corners and pull the panel towards yourself.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 24-59, Amido Spring 2011 Mitglied von Cal Poly, Team 24-59, Amido Spring 2011
CPSU-AMIDO-S11S24G59
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 1,822
