Einleitung
Install an Airport Extreme 802.11g card internally.
Was du brauchst
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Flip down the door on the right side of the battery compartment.
Use a spudger or flathead screwdriver to disconnect the Airport antenna from the card.
24 weitere Nutzer:innen haben diese Anleitung absolviert.
