Zum Hauptinhalt wechseln
Einleitung
Install an Airport Extreme 802.11g card internally.
  1. Use a coin to turn the battery locking screw 90 degrees to the right.
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. Flip down the door on the right side of the battery compartment.
    • Flip down the door on the right side of the battery compartment.
  3. Use a spudger to disconnect the Airport antenna from the card.
    • Use a spudger to disconnect the Airport antenna from the card.
  4. Grasp the plastic tab and pull the card out all the way.
    • Grasp the plastic tab and pull the card out all the way.
Abschluss
11 weitere Nutzer haben diese Anleitung absolviert.
Angehängte Dateien
iRobot
1 Reputation
647 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 4
Insgesamt: 10,597
