Einleitung
Upgrade your hard drive for more storage space.
Was du brauchst
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Use the flat end of a spudger to pry the sound card ribbon cable connector up off the logic board.
Move the sound card ribbon cable away from the face of the hard drive.
Use the flat end of a spudger to pry the hard drive ribbon cable connector up off the logic board.
Remove the following four screws:
Three 11.1 mm T8 Torx.
One 3.9 mm T8 Torx.
Lift the hard drive out of the lower case.
Pull the hard drive cable straight away from the hard drive. It is helpful to wiggle the connector while pulling it away from the hard drive.
Remove the two Phillips screws from the right side of the hard drive.
Pull the right hard drive bracket away from the hard drive.
If necessary, peel the piece of tape holding the left hard drive bracket to the hard drive shield off the hard drive shield.
Remove the two Phillips screws from the left side of the hard drive.
Pull the hard drive bracket away from the hard drive.
Use the flat end of a spudger to separate the adhesive holding the hard drive shield on the hard drive.
39 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
5 Kommentare
When putting the keyboard back in, be sure to slip the Z ribbon through the slot so that it can be locked back in. Be sure that it is locked well.
Great guide. All in all, this is pretty easy but I've hit a snag with the hard drive. I have a PowerBook5,6 and a PowerBook5,9.
I want to simply transfer the actual hard drive from my older model to the 17" model. The SSD works fine in my 15" PowerBook but the 17" doesn't see it. It boots to a grey screen and stays there. When I boot from my Leopard install DVD, that works but Disk Utilities doesn't show a hard drive at all. I rechecked cables & attachments.
The 480GB SSD is formatted with Apple Partition Map and OS Extended Journaled. It works fine when I return it to the 15" and the 17" works fine with its IDE drive.
I thought this would be an easy swap. What might I be missing? What is different with the A1139?
Thanks.
Not sure why, but my 17” PowerBook5,9 A1139 just doesn’t like the 480GB OWC Legacy Mercury Electra G3 SSDs. I did not try smaller OWC SSDs. I eventually found that KingSpec 512GB PATA/IDE SSD works fine on the first go. Previously, I was using a Western Digital Scorpion Blue 320GB, WD3200BEVE
I used Carbon Copy Cloner to clone my WD to the KingSpec, then checked and verified the KingSpec before disassembling the PowerBook and installing the new drive. I have two USB adapters for PATA/IDE drives. One uses a single connector, the other uses a 2nd USB connector for additional power. The KingSpec worked better with the dual USB connector adapter. With the single USB, the driver would intermittently disappear and only reappear if disconnected/reconnected.
As an additional note/suggestion, I keep a bootable harddrive back-up on an external firewire drive. This older PowerBookG4 won’t boot from a USB drive. Having a current back-up on an external bootable firewire drive comes in very handy.
JaesonK
jaesonk -
hi, do you use a genuine ssd with IDE connections or do you use an adapter ( like Renkforce etc) with mSata ? my powerbook only could recognize the mSata on my Renkforce adapter when I removed the little cable selector pin on the adapter. ( automatically master) After that it was recognized instantly.
Jamba -
Very nicely done, thank you. Would this instruction work for an PowerBook G4 Aluminum 17" 1.33 GHz model as well?
Thanks!
