Einleitung
This guide shows the hidden screws you must remove when replacing the keyboard.
Ersatzteile
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Remove the two Phillips screws securing the electronic track pad button to the lower case.
Use your fingernails or the tip of a spudger to separate the ZIF cable lock from its socket.
Use the tip of a spudger to pull the track pad ribbon cable out of its socket.
Disconnect both of the following connectors from the logic board:
Sleep sensor cable.
Power button cable.
Starting near the keyboard, use the flat end of a spudger to help separate the adhesive as you peel back the track pad ribbon cable.
Use the tip of a spudger to pry up the ribbon cable retaining flaps on both the keyboard and backlight ribbon cable sockets.
Remove the large protective sticker from the underside of the keyboard enclosure on the lower case.
Use the tip of a spudger to bend each of the four keyboard lock tabs away from the underside of the keyboard enclosure on the lower case.
Use the tip of a spudger to push a screw lug near the center of the keyboard, separating it from the lower case.
Bow the keyboard out slightly to release the two tabs near the upper corner on each side of the keyboard.
Rotate the keyboard toward yourself and lift it out of the upper case.
3 weitere Nutzer haben diese Anleitung absolviert.
Angehängte Dateien
2 Kommentare
Excellent detailed instructions and cautions. Even the magnified pictures are very good. A bit more complicated than a Dell or Toshiba. Mahalo.
there’s a connector for the power button on the orange ribbon that doesn’t slip through slit - WTF?
