Zum Hauptinhalt wechseln
PowerBook G4 Titanium DVI Hard Drive Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. PowerBook G4 Titanium DVI Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 PowerBook G4 Titanium DVI Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Hard Drive Replacement, Lower Case: Schritt 2, Bild 1 von 2 PowerBook G4 Titanium DVI Hard Drive Replacement, Lower Case: Schritt 2, Bild 2 von 2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  4. PowerBook G4 Titanium DVI Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  5. PowerBook G4 Titanium DVI Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  6. PowerBook G4 Titanium DVI Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Your laptop should look approximately like this.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 15
Insgesamt: 13,724
