Einleitung
The 56k internal modem is attached to the optical drive and standard on all models.
Was du brauchst
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
Remove the two silver T8 Torx screws from the black plastic bar.
Lift the black plastic bar out.
Disconnect the two orange connectors from the logic board, removing tape as necessary.
Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
Remove the two T6 Torx screws from the modem.
Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
Eine weitere Person hat diese Anleitung absolviert.
