Zum Hauptinhalt wechseln
Einleitung
How to remove the combo or SuperDrive, including the attached modem and display inverter.
  1. Locate the battery release tab on the underside of the G4. Slide the battery release tab to the left and lift the battery out of the computer.
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. Remove the seven T8 Torx screws from the lower case. Using your thumbs, slide the lower case toward the front of the computer.
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  4. To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  5. Remove the hard drive by lifting the left edge up and out of the computer.
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  6. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
  7. Disconnect and remove the indicated orange ribbon cable.
    • Disconnect and remove the indicated orange ribbon cable.
  8. Disconnect the pink and white inverter cable from the inverter board.
    • Disconnect the pink and white inverter cable from the inverter board.
    • The display inverter has orange plastic shielding around it that looks similar to the tape used elsewhere within the computer. Do not remove the shielding from the inverter.
  9. Remove the two silver T8 Torx screws from the black plastic bar.
    • Remove the two silver T8 Torx screws from the black plastic bar.
    • Lift the black plastic bar out.
    • Reassembly will be significantly easier if you reseat the hard drive before returning the black bar to its place.
  10. Disconnect the two orange connectors from the logic board, removing tape as necessary.
    • Disconnect the two orange connectors from the logic board, removing tape as necessary.
  11. Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
    • Lift the drive up on the right side so that you can access and disconnect the modem cable and inverter cable.
  12. Remove the drive by lifting the right edge up and out of the computer.
    • Remove the drive by lifting the right edge up and out of the computer.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Angehängte Dateien
iRobot
1 Reputation
646 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 9,766
