Einleitung
How to remove the hard drive, along with its cable and bracket from your computer.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Turn the G4 over.
Remove the eight Phillips screws from the lower case.
Using your thumbs, slide the lower case away from you.
Lift the lower case off.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
7 weitere Nutzer haben diese Anleitung absolviert.
