Zum Hauptinhalt wechseln
PowerBook G4 Titanium Mercury PC Card Cage Replacement
Was du brauchst
  1. PowerBook G4 Titanium Mercury PC Card Cage Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the battery.
    • Turn the keyboard locking screw so that it is parallel to the space bar.
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  2. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 2, Bild 1 von 1
    • Rest the keyboard face down on the trackpad area.
    • Disconnect the keyboard connector from the logic board.
  3. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 3, Bild 1 von 1
    • Your laptop should look approximately like this.
  4. PowerBook G4 Titanium Mercury PC Card Cage Replacement, RAM: Schritt 4, Bild 1 von 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the RAM chip out.
    • Repeat this process if a second RAM chip is installed.
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
  5. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 6, Bild 1 von 1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  6. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 7, Bild 1 von 1
  7. PowerBook G4 Titanium Mercury PC Card Cage Replacement, Airport Card: Schritt 8, Bild 1 von 1
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
  8. PowerBook G4 Titanium Mercury PC Card Cage Replacement, Hard Drive: Schritt 9, Bild 1 von 1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  9. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 10, Bild 1 von 1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  10. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 11, Bild 1 von 1
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  11. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 12, Bild 1 von 1
  12. PowerBook G4 Titanium Mercury PC Card Cage Replacement, DVD Drive: Schritt 13, Bild 1 von 1
    • Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
    • Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
  13. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 14, Bild 1 von 1
    • Bend the silver metal EMI clip so that it is vertical. This part may fall out after removing the DVD drive.
    • The EMI clip is not essential for reassembling the computer. If the clip falls out, don't worry about putting it back in.
  14. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 15, Bild 1 von 1
    • Turn the G4 over.
    • Disconnect both orange ribbon cables from the logic board using a spudger or the tip of your finger.
  15. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 16, Bild 1 von 1
    • Remove the DVD drive by lifting the right edge up and out of the computer.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
  16. PowerBook G4 Titanium Mercury PC Card Cage Replacement, Modem: Schritt 17, Bild 1 von 1
    • Turn the G4 over.
    • Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
  17. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 18, Bild 1 von 1
    • Lift the modem out by pulling up and to the right.
    • The plastic shielding on the modem may catch on the computer's case. Rocking the modem from side to side will help free the modem.
  18. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 19, Bild 1 von 1
    • Disconnect the connector cable from the modem.
  19. PowerBook G4 Titanium Mercury PC Card Cage Replacement, PMU: Schritt 20, Bild 1 von 1
    • Turn the G4 over.
    • Peel the orange tape away from the three connectors on the PMU board. Leave this tape in place so you can reuse it when reassembling the G4.
    • Disconnect the two orange cables and one multicolored cable from the PMU.
  20. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 21, Bild 1 von 1
    • Lift up on the silver metal clip to free the PMU from the casing.
    • Remove the PMU rotating it clockwise and pulling up.
  21. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 22, Bild 1 von 1
  22. PowerBook G4 Titanium Mercury PC Card Cage Replacement, Logic Board: Schritt 23, Bild 1 von 1
    • Turn the G4 over and rest it on a soft cloth.
    • Disconnect the multicolored fan connector and battery connector from the logic board.
    • Disconnect the orange PC card cage connector from the logic board.
  23. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 24, Bild 1 von 1
    • Remove the single T8 Torx screw located next to the PC Card cage.
  24. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 25, Bild 1 von 1
    • Turn the G4 over.
    • Remove the two T8 Torx screws from the middle of the logic board.
  25. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 26, Bild 1 von 1
    • Disconnect the four indicated connectors from the logic board, removing tape as necessary.
  26. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 27, Bild 1 von 1
    • Carefully lift the logic board up and pull it away from you. The logic board may catch on the back panel ports liner. If this occurs, use a spudger or non-metal tool to free the logic board.
    • This step requires some force, but if the logic board will not come up, make sure you have removed all screws and connectors necessary.
    • Remove the logic board from the computer.
  27. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 28, Bild 1 von 1
  28. PowerBook G4 Titanium Mercury PC Card Cage Replacement, PC Card Cage: Schritt 29, Bild 1 von 1
    • Remove the two T8 Torx screws that secure the PC Card cage.
  29. PowerBook G4 Titanium Mercury PC Card Cage Replacement: Schritt 30, Bild 1 von 1
    • Remove the PC Card cage by pulling it to the right and twisting slightly toward you.
Abschluss
Angehängte Dokumente
iRobot
1 Reputation
635 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 5,480
