Einleitung
Install an original Airport 802.11b card internally.
Was du brauchst
Turn the G4 over.
Remove the eight T8 Torx screws from the lower case.
Using your thumbs, slide the lower case away from you.
Lift the lower case off.
Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
Disconnect the antenna cable from the left side of the Airport card.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
